How do I add an alpha channel in PF6 ?
shagger1
- Version de PhotoFiltre : 6
- Système d'exploitation : ME/XP
- Processeur : intel 1400
- Mémoire RAM : 512
I am trying to use a photoshop plugin but it says the image requires an alpha channel for it to work-how would I add this (photofiltre) and what format would I save it in??
shagger1
- Mémoire RAM : 512
Hi Shagger,
sorry i had not understood the context.
Try Menu/Image/Mask transparency or something like (i haven't installed the english release).
Then you can observ that Image/mode is changed now in Indexed colours .
You can save the picture in any type for transparency available in the choice box, but png is best than gif.
cheers.
cheers.
shagger1
- Mémoire RAM : 512
When you save in png or gif the mask of transparency you get the alpha channel.
Then you copy this mask. On the original image you do use Edit/Paste special/Mask and with a right clic, Options to adjust opacity.
The result must be saved also in png. Then i suppose you get the good result.
I had never practiced this way and i hope it's the right one.
Other way, i think you would ask on a Gimp forum.
Cheers
Cheers
