Show RGB value next to cursor.
Badger21vb
Processeur : 8605b965faa71193de0213e00ebaf722
Mémoire RAM : 0
Message par Badger21vb »
Is it possible to get the RGB value, of the pixelcolor under the corsor, shown next to the cursor?
So that as you move the cursor over different colors, you can see the new value without having to click first, and loose focus. (Used in fine picture retouch)
Hi Badger,
I presume you talk about the cursor of the pipette tool.
Yes it will be serviceable.
I hope Antonio could add this information somewhere on the workpage, like the polar coordinates of the cursor.
Badger21vb
Mémoire RAM : 0
Tom a écrit :Hi Badger,
I presume you talk about the cursor of the pipette tool.....
That is the one yes. And yes "polar coordinates of the cursor" would also be nice to have.
Yes Badger,
Polar coordinates of the cursor are displaid in the State bar on the workspace bottom.
Like this position, the color of the cursor could be displaid there. :wink:
Badger21vb
Mémoire RAM : 0
Tom a écrit :Yes Badger,
Sorry for the long replytime. (Vacation)
The coordinates I see fine. No problem.
But for the colors I have to click on each pixel to get the colorcode, it does not change as the mouse moves over the pixels.
Also it is located in bottom of the right side panel. And it is called 'Web'
Hi Badger,
yes i know the pipette tool.
But i think Antonio is rather busy and has not defined this feature in his priorities for the moment.
