PhotoFiltre Studio 7.3
Bill
Version de PhotoFiltre : Free and Studio
Système d'exploitation : Coffee
Processeur : God Given Brain
Mémoire RAM : Not as well as when I was younger
Message par Bill »
Antonio:
Thanks for the new update. I have a new site dedicated to PhotoFIltre Studio only and have been waiting until the new release before I openned it.
An Observation:
The Screen mode for Layer Blending is too agressive for the Highlights and washes them out completely.
The effect should be a little like the opposite of Multiply.
jimclatfelter
Système d'exploitation : Windows Vista
Processeur : AMD Athlon X2
Message par jimclatfelter »
When will 7.3 be available to us registered PFS users? I don't see it on the website.
Jim
Heis Spiter
Mémoire RAM : 1536 Mo DDR
Message par Heis Spiter »
Probably a few days after Antonio came back.
jimclatfelter
That's great news. I use PFS for everything. The only time I use another photo editor is when I need blend modes. Now I will use PFS exclusively.
By the way, I have changed my website to http://8bf.net There are some new 8bf plug-ins there. They're free if anyone wants to download the zip files.
Bill
Message par Bill »
Jim:
I found out about it on the Support Technique Forum.
Here is my 1st Tutorial Salvage an Under Exposed Image. I'm waiting for all the refinements before I jump in don't want to have to redo them :D
Below is the original and result:
I'll check out your filters and do a mini review on my site for ones I see use for.
Image Image
jimclatfelter
Hi Bill,
Thanks for offering a link. Screen and multiply are great for under- and over- exposed images. I did have a filter for this, but I took it off. It was called multi-filter. It combined the image with a copy of itself in either screen or multiply mode. It even had overlay for greater contrast. But layer blending is much more versatile, since the two layers don't have to be the same. I'm really excited that layer blending is coming.
I'll put a link to your Studio website on the 8bf.net home page. I love this program. It's so fast and easy to understand. And it does so much.
You can download the beta release :wink: viewtopic.php?t=4654
jimclatfelter
Thanks for the link Francois. I downloaded the beta. It will be great to have blending modes.
Screen mode looks too bright to me too. I used this formula for screen mode on my filter:
255 - (255-a) * (255-b) / 255
where a is the layer under b
This formula does not increase the contrast so much.
carlo taradel
Version de PhotoFiltre : PF-PFS
Système d'exploitation : win XP pro- ubuntu_ breeze
Processeur : recycled from waste bin
Mémoire RAM : 1026
Message par carlo taradel »
forom Bill
a dumb question: where is the Layer blending menu ,i didn't find it
there is a color option?
carlo taradel
Mémoire RAM : 1026
:D Problem solved :!:
I find it ! (thank to Bill tutorial), excuse me for the dumb question :!:
carlo taradel
Mémoire RAM : 1026
:( But why in PFS the color blending mode create such big nasty pixel?
Any idea to correct this in the next stable realease :?:
The Screen mode for Layer Blending is too agressiv==> ce mode correspond à la somme des composantes couleurs, soit :
RR = Max(255, R1 + R2)
GG = Max(255, G1 + G2)
BB = Max(255, B1 + B2)
==> Il faut convertir RGB en HSL puis à nouveau HSL en RGB. Ca provoque des pertes et des arrondis et les calcules ne sont pas très précis. En plus c'est très lent :cry:
jimclatfelter
RR = 255 - (255-R1) * (255-R2) / 255
GG = 255 - (255-G1) * (255-G2) / 255
BB = 255 - (255-B1) * (255-B2) / 255
This is the formula I used for Screen mode. I got it from the FilterMeister documentation. It doesn't wash out the highlights so much.
Ok, je teste ça. C'est quoi les autres formues (des modes de fusion) pour que je compare avec ce que j'ai fait dans PFS ?
Bill
Message par Bill »
Here's an example of the problem:
I tested this image and process with Photoshop, Corel PhotoPaint, Ulead Photo Impact, and Mediachance Real Draw Pro all of these programs produced the same result.
1) Inserted the Image.
2) Created a duplicate layer.
3) Blurred the top layer and set the Blending Mode to Screen.
1st image is the original, 2nd is the result from PhotoFiltre and the 3rd from PS.
