Question About HTML Split Plug-In
Jael
Version de PhotoFiltre : 6.1.5
Système d'exploitation : ME
Processeur : 1G AMD Duron
Mémoire RAM : 384 MB
Message par Jael »
Hello,
This may be a dumb question, :oops: but can an image that has been split using the HTML Split plugin be used as hyperlink in the same manner that a regular image can be (I noticed that it codes it as a table) - and if so, how would this be accomplished?
Thanks!
Hi Jael,
There is no dumb question, but you can try it by yourself. :wink:
Any html page composer is able to intoduce a link behind an image.
In this case, if you wish link a page through all the splits of the image you do put a link behind each of them.
Other way, to use this image as a menu, you can bind each split to a different page.
The code will seem like this :
<td width="267"><a href="url_html_page"><img src="image_mel1s2s.jpg"></td>
You can see this page for an idea of menu :
http://www.network.philtre.free.fr/galeries.htm
Jael
Message par Jael »
Thank you, Tom. :)
I'm not using a composer but rather coding manually in an attempt to teach myself HTML. If I am understanding you correctly, I would just need to insert the path ( “a href="index.html" for example) between each "td width=242" and "img src="images\cross1s1s.jpg"></td" - is that correct?
The image will not be used as a menu, so the path will be the same for each split, but thank you for the example. If that was your site, allow me to compliment your artistic talent! I couldn't read a word there - but I'm definitely going back to look at the pictures! :wink:
Yes it's correct Jael,
You have only to add the path. I have tried it. :wink:
No sorry, it's not my site, and i regret strongly. Ricochet, the author, publishes regularly some very fine pictures on this forum.
I was very pleased to read you. Best greetings.
Jael
Message par Jael »
Ok, thank you very much for the help! :)
