How do I save 4 images together on PhotoFiltre?
Carole Alexander
Système d'exploitation : Windows XP Home
Message par Carole Alexander »
Hi All
I'm trying to make a logo for my Web site and have saved 4 images in a new folder on PhotoFiltre.
When I go into window on the toolbar I can arrange them all into a horizontal line.
My problem is - how do I save them as one image.
Any ideas :?:
Thanks
Carole
Copy one image and use the function Edit > paste special > Assemble.
Repeat this operation for all images
Carole Alexander
Antonio - when I do this I just get a copy of each one :(
I want to have the 4 different images next to each other and then save them as 1 image.
Can I do this :?:
Yes Carole,
For more precision :
Copy the picture N°2 and Paste special/assemble on the first picture.
Then the picture N°3 on the first one and so on.
Carole Alexander
Hi Tom
It's great up until I get to picture No 2.
I copy, go to edit and paste special then assemble - then this is where the problem is:
When you get to assembe it gives you 4 options.
To save top, bottom, left or right - it doesn't give you the option to assemble on the first picture.
How do you do this :?:
Thanks
Carole
Hi Carole,
At once, duplicate all the pictures to prevent any loss or failure.
Then, PhotoFiltre is warranted against any explosure of your computer. :lol:
So you may try and try again, the undo button helps you to go back the correct step you wish. :wink:
Tom a écrit :For more precision :
Open the first picture
Paste special/assemble.
Carole Alexander
Hi Tom
I went for a walk and just tried again - it sure stresses you :evil:
I thought I was doing well and have loads of duplicates saved under new names. I had 2 pictures up and then when I went to do No3 the 'paste special' was no longer highlighted so I can't go on to assemble.
I now have so many duplicates saved under different names and although I do press UNDO nothing happens :twisted:
Have you any ideas? In the meantime I'm going to look for more pictures and try again.
Thanks for your help - I'll get there eventually :wink:
Carole
Try that:
Image 1 + image 2 : Paste special/assemble . Save with other name (collage 1 for example)
Image 3 + image 4 : Paste special/assemble. Save with other name (collage 2 for example).
And now assemble collage1 and collage 2
Carole Alexander
I tried it Patrick but it still doesn't work :cry:
I'll give it a rest for tonight and try again tomorrow.
Thanks for the help :)
Carole
Carole Alexander
Patrick you truly are a genius - it works :D
One last thing - do you know how I put a border around it :?:
Thanks Carole
Use Image/Outside frame :wink:
Carole Alexander
I found it yesterday :wink:
But thank you very much for all the help :)
Carole
Carole Alexander
I forgot to ask if you know how to blur the edges of the pictures together :?:
At the moment I have put borders around each picture and then another border around all 5 pictures.
Thanks
Carole
