So i make a folder C:\document\favorite (8bf) with ONLYthe most used and using "preference" i set the path there,and everything is fine.
To save space on hard disk i copy all the other on DVD,in a folder called 8bf,with several subfolder (To be checked,kaleidoskope effect,black and white,psichedelic....)and when i look for something new i change the path to D:8bf\to be checked,or something alike.
Pfs will load slower,and also filtre will work slower but for the rest everything work fine,when i find some very useful filter i just move it to C:\document\that I use like default path
THIS COULD BE THE TIP BUT THERE IS A ERROR MESSAGE WHEN I SET THE PATH IN D OR IN E(E=USB PENDRIVE) IT IS THE FOLLOWING:
iMPOSSIBLE FIND THE ACCESS TO IsiDlgButton IN USER32dll.
This it seem no connected with any problem...BUT WHAT IS THE"IsiDlgButton" and The USER32.Dll ?I had to worry about this message?
IF i Will put a copy of This USERdll along the path this will solve the problem?
NOTE
I almost forgot ,when the path is changed to D or E for some reason Plugin Dll will not be found also if present in the System 32 folder...it has to be put a new copy in the 8bf folder. (at least this works on my pc)...
Again this trick have to be done only for all the filter that are almost never used,the most used one must stay always in C(hard disk)
