Plugins and Filters
Kingster
Plugins and Filters
Message par Kingster »
After downloading and unzipping filters and plugins, how do I get Photfiltre to recongnize the new filters and plugins.
Thanks
Larry
Benjamin
Version de PhotoFiltre : 6.0
Mémoire RAM : 512Mo DDR 333
Message par Benjamin »
You must unzip plugins in the PhotoFiltre Plugins subdirectory... PhotoFiltre will recognize them automatiquely...
Invité
Message par Invité »
Hi guys,
I've tried to install Italian Language plug-in.
I have downloaded the plug-in, unzipped in "PhotoFiltre\plugins" directory and resterted PhotoFiltre...
but is always in english...
can you help me?
thanks
Languages are not plugins :wink:
*.pfl files must be unzipped in the same directory as PhotoFiltre.exe (or pf-studio.exe)
Jaume44
Système d'exploitation : w7
dll
Message par Jaume44 »
8bf plugins function in PF Studio.
Check and make certain you have the proper dll files in your Systme32 folder...providing you are using a PC OS.
The two files in particular are: MSVCRT10.dll and PLUGIN.dll. You should have these in you PF folder, if not, you may obtain them readily online.
carlo taradel
Version de PhotoFiltre : PF-PFS
Système d'exploitation : win XP pro- ubuntu_ breeze
Processeur : recycled from waste bin
Mémoire RAM : 1026
Message par carlo taradel »
:D Ciao...Se guardi dentro la cartella di photofiltre(in windows xp clicca su start,POI nel menu che si apre clicca su cerca/ cartelle /disco rigido/programmi /photofiltre li vedrai una cartella chiamata Studio EN.plg (o Studio FR:plg se hai la versione francese)
DEVI ELIMINARLA( O RINOMINARLA "Studio Z.plg" per esempio,SE CI SONO 2 O PIU' CARTELLE ".plg" VIENE SCELTA AUTOMATICAMENTE LA PRIMA IN ORDINE ALFABETICO :!: ) E TRASCINARE AL SUO POSTO QUELLA CONTENUTA NEL LANGUAGE PACK ITALIANO.:!:
Non ricordo se é compressa se lo è (se Il nome finisce con ".zip") OVVIAMENTE PRIMA DEVI APRIRE LA ZIP ,BASTA CLICCARCI 2 VOLTE...ED AVRAI PF IN ITALIANO
NON DEVI METTERLA NELLE ALTRE CARTELLE
è MOLTO PIù FACILE FARLO CHE SPIEGARLO... 8)
carlo taradel
Mémoire RAM : 1026
:oops: The answer in italian was for Invitè...i didn't notice that his message was from june...sorry :oops:
So may I delete your two posts ?
carlo taradel
Mémoire RAM : 1026
8) Well the one in italian maybe could be useful for all italians,it's a simple step by step "how to" for the installation of the Italian Language Pack (that is little tricky) :!:
The title is wrong "PF Come installare la versione italiana"lit will be much better :!:
Some people make confusion with Plugin and Language Pack...But It will be maybe much more useful that info moved in "support elteno"..... than lost in the "plugin"" forum ,where is out of topic
message 2 (in english)was just my excuse... sure you can delete it8)
