pf
Messages : 974 Inscription : 28 avr. 2004 8:45
Version de PhotoFiltre : 6
Système d'exploitation : xp seven
Message
par pf » 21 nov. 2005 20:23
Hi All,,
New version 2.1 beta
- 9 Forms.
- 8 Styles
- Variable angle for all the forms
- Regular polygons
Save/load for Soon !!!!!!!
A+
Dernière modification par pf le 30 mars 2008 23:34, modifié 3 fois.
Jaume44
Messages : 448 Inscription : 09 mars 2005 21:42
Version de PhotoFiltre : Studio 10
Système d'exploitation : w7
Processeur : Pentium (R) Dual Core
Mémoire RAM : 4 GB
Message
par Jaume44 » 22 nov. 2005 12:21
Below is a sample of the new gradient filter, BETA. I like it a lot.
Only the satin background has the new filter effect as a layer over the texture opaqued. It is simple
form right with the
style constatnt . I will be studying the various forms and usage, but it would be very nice if anyone would submit an example of his work using one of the other forms. I like the filter a lot, and I know it will come in handy. Could a transparancy slide be incorporated into the filter? That would be great.
pf
Message
par pf » 22 nov. 2005 12:33
Jaume44 a écrit : .....Could a transparancy slide be incorporated into the filter? That would be great......
It is envisaged but not for soon....... Much problems
Nice sample
Tanks
A+
Jaume44
Mémoire RAM : 4 GB
Message
par Jaume44 » 22 nov. 2005 13:19
Until then, to get around it, folks may do what I did, make a blank layer, place the desired gradient on that layer, then go to the options of the layer and use the transparancy feature there...... Actually, I was just being my lazy self suggesting a slide.
JojoUtrecht
Messages : 1 Inscription : 01 août 2007 15:07
Message
par JojoUtrecht » 01 août 2007 15:23
The ZIP HERE-link doesn't exist. It leads to a general search-page of Orange (Page introuvable), where no zip-file can be found.
Is there perhaps another location?
Greetings, JojoUtrecht
Messages : 13355 Inscription : 02 févr. 2005 9:35
Message
par Tom » 01 août 2007 15:28
JojoUtrecht a écrit : Is there perhaps another location?
Indeed yes, the best location :
http://www.photofiltre-studio.com/plugi ... ins-en.htm
[Tom] link updated : 2012/06/18 [/Tom]
Mészáros Tamás
Messages : 126 Inscription : 13 juin 2006 11:44
Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
Système d'exploitation : Win 7 Home Premium SP1
Processeur : AMD II X2 Athlon 265 3.3 GHz
Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Message
par Mészáros Tamás » 18 juin 2012 10:37
Not found this link. Sorry.
Message
par Tom » 18 juin 2012 11:17
Updated
