Clone Stamp in PhotoFiltre Studio
TKay
Message par TKay »
Can the Clone Stamp tool sample from all layers?
Bill
Version de PhotoFiltre : Free and Studio
Système d'exploitation : Coffee
Processeur : God Given Brain
Mémoire RAM : Not as well as when I was younger
Message par Bill »
Not at this time but Antonio is always tinkering :wink:
TKay
Message par TKay »
Thanks for the reply.
This function is really needed ?
Bill
Message par Bill »
I can tell you as a person who does a lot of photomanipulation that I find the feature very useful.
The best program I have ever worked with that has this feature is RealDraw Pro by Mediachance. If you follow the link below you will see a tutorial I did about 5 years ago and the result from using this feature.
http://www.realdrawcafe.com/clean/tutor ... index.html
Jaume44
Système d'exploitation : w7
Feature
Message par Jaume44 »
It would be not only a useful feature, but unique, to be able to clone from one layer to another, however when there are more than two layers, it seems the writing of such a sofware feature would become quite monumental, although I know nothing about programming. Does this comment make any sense whatsoever? :?
==> You can use a layer as pattern (menu Edit) and select pattern option on the clone stamp tool
