Small bug when using PgDn / PgUp in PF 6.1.5
dvesic
Message par dvesic »
Hello.
There is small bug in PF 6.1.5 when you use PgDn / PgUp to select next / previous image:
1. Open image
2. start changing active image with PgDn and/or PgUp
3. In the Window menu, name of the image will stays from (1), no matter on which image you are really now.
(i.e. there is no update of Window menu element).
Regards,
Dejan
Well noticed :wink:
This bug is in the two PF versions.
