menu filter - colour - coloured laayer - inverser
Marga
Version de PhotoFiltre : PF and PFS
Système d'exploitation : W7
Mémoire RAM : 3
Message par Marga »
Hi all,
Please can someone tell me what means INVERSER in the menu Filter - Colour - coloured layer.
I inset a capture from the French edition:
Cordialement,
Marga (Holland)
It's useful when you have to remove a colored layer, for example on a photo taken indoor (with artificial light), with the wrong color settings that create an horrible orange layer :wink: In this case you choose orange and you check Inverser. That removes the color.
Marga
Mémoire RAM : 3
coloured layer inverse
Message par Marga »
Thank you, this is an absolute eye-opener for me..... just tried it out... works fine. On a misty day (we have many over here now) you make a picture and with this option it still can be finelooking!
Cordialement (my French is improving)
Marga
Hi Marga,
To follow and complete the explanation from François, i propose you to have a glance at this colors wheel :
You can find a tutorial (in french) on the site of Cath :
http://catland.chez.tiscali.fr/graphofi ... oto_01.htm
In few words :
- you can attenuate a color like in the last post of François.
- you can also use this wheel to quickly find the right inverse color to increase an other hue.
For more precision in the color choice, you can open this picture with PF and select inverse of the right color with the pipette.
- Ctrl Tab and you are back on your first picture
- Menu Filter/Colour/Colored filter and you can select the foreground color of the pallet.
Marga
Mémoire RAM : 3
Message par Marga »
Super, you made me happy with this extra option.....
Thank you.
Cordialement (my French is improving...)
Marga
