8bf plugins not accessible
Marga
Version de PhotoFiltre : PF and PFS
Système d'exploitation : W7
Mémoire RAM : 3
Message par Marga »
Hi all,
After installation of the exe-file installing all the plugins my 8bf -files are not actif anymore...
Is that coincidence or something else......???
Greetings, Marga
Hi Marga,
- At first, close PhotoFiltre.
- You have to verify if you haven't several folders named as PhotoFiltre.
- Inside the good PhotoFiltre folder, a folder named Plugins must contain a file named "8BF.pfl", weight 64 Ko.
- Then, open PFStudio and map the right way to the 8BF filters folder.
and don't forget :
PhotoFiltre moet opnieuw gestart worden. :wink:
