[Beta test]A plugin against red eyes
Hi Alain,
Thanks for this new release.
It works very quickly and quite fine.
(a little red edge remains around the iris) :wink:
For most of cases it will be very usefull, if any zooming is not required.
Great Job, the french buttons will be appreciated.
If the title, which appears in the plugin list, could be also translated, it will be perfect.
Greetings. :wink:
matama_1
Processeur : 5ebe2225d153aa0c752416f62a3fadcc
Mémoire RAM : 1
Message par matama_1 »
@ Alain
Thanks for this plugin
It works fine.
greetings
Alain
Mémoire RAM : 1024
Message par Alain »
Hi Tom
Tom a écrit :Hi Alain,
Greetings. :wink:
I did translate the title and some other extra fields in version 0.93, can you test it?
Alain
Yes i do.
Result of test in a little half an hour. :wink:
Edit : time is going very fast. :wink:
For title : "Yeux rouges" is quite enough. "Fix" is not necessary : idealy, it would be translated by "correction" but it's too lengthy for this place and inessential.
The others items are perfectly clear, and the txt file too.
Thanks and greetings.
It's a very good job for the PF6 users. :wink:
Alain
Mémoire RAM : 1024
Message par Alain »
Tom a écrit :Yes i do.
Thanks
title corrected (still as 0.93). If I don't hear problems I will make a 1.0 in a few days.
Alain
Alain
Mémoire RAM : 1024
Message par Alain »
Hi
The version 1.0 is available from the plugin section of the website.
Alain
OK, so I remove the post-it :wink:
Bonjour Alain et François,
il manque un "s" à Yeux rouges dans le titre sur la description du plugin sur le site PF
It miss an "s" at "Yeux rouges" in the title of the plugin description on the PF site.
Alain
Mémoire RAM : 1024
Message par Alain »
Tom a écrit :Bonjour Alain et François,
Changed, thanks.
Alain
