Filtering-out Telephone Cables
pvsurfer
Système d'exploitation : WinXP Pro (SP2)
Processeur : P4C 2.8
Mémoire RAM : 1GB
Message par pvsurfer »
New user here... I have quite a few pictures which are less than what they could be because of (horizontal) telephone-pole cables getting in the way. So I was wondering if PhotoFiltre Studio can somehow 'filter' them out. :?:
Any help/advice would be most appreciated. ~pv
[Tom] I tag this topic as [Ref] Reference or recommandation for research [/Tom]
Bill
Version de PhotoFiltre : Free and Studio
Système d'exploitation : Coffee
Processeur : God Given Brain
Mémoire RAM : Not as well as when I was younger
Message par Bill »
Have you tried the Clone / Stamp Tool ?
pvsurfer
Mémoire RAM : 1GB
Bill a écrit :Have you tried the Clone / Stamp Tool ?
No I haven't Bill - as I said "new user here" and as of now I don't have a clue how to use PF's Tools! There's not much (that I can find) in the way of a user-manual, and I just now clicked on your Tips & Tricks link... So how do you suggest a beginner get started with this app? :?:
Jaume44
Système d'exploitation : w7
Yes
Message par Jaume44 »
By all means, use the clone tool; it is ideal.
Below is a sample photo of what it does. Begin with the largest copy available of what you wish to clone. I begin away from any junctures with the pixels higher, in this sample 20 radius. When the tool is really close to the juncture with the building the radius was reduced to 7. The radius will vary according to the available cloning source pattern or color. Should the track of the clone be slightly apparant after cloning, you may use the smear tool or the blur tool. It is surprising how the hands-on approach makes all of this routine.
New update,
with the last Studio 8 release, the magic erase in the retouch tools can solve this question, as well as the Clone stamp tool.
