how to Move a selection?
luckman212
Message par luckman212 »
Hello,
maybe this is a very basic question but how do you move a selection, and I mean move the actual pixels, not the selection rectangle itself.
So I am trying to open an image, and select an area, and then MOVE the pixels themselves.
In Photoshop, you can select an area, then type "V" and move the pixels in that layer. So I was hoping for some similar procedure in PF.
can it be done? thank you, merci
:wink:
you need to copy and paste
luckman212
but then a new layer would be added? what If I just want to move the pixels .. .there is no way to achieve this?
Ctrl C in your selection. Move your selection at the good place, right button of the mouse and choose Paste in > Adjust size
and CTRL+Enter to flatten image
luckman212
I think CUT (ctrl-X) and paste (ctrl-V) and then flatten (ctrl-enter) is a lot of steps just to nudge some pixels .... to me it is such a basic function of a graphics program to be able to move pixels around I am surprised to see such a powerful program doesnt have this feature
but (sigh) i suppose its life
thanks
==> I don' like this function, I never use it. In a photo, I don't want to move pixels, I copy and paste only.
Hi luckman
Have you the stamp tool tried ?
It does quickly and nearly that you have described.
If you combine the stamp tool with a selection, that you have copied will only in the selection be pasted, and not beyond.
In other words, copy with the stamp a large area, and the selection will crop the pasted area.
Other way to do exactly that you want :
- select an area.
- Edit/Use as pattern
- move your selection at the right place you want
- Edit/Fill with pattern
No layers will be added.
Have nice satisfactions with PFStudio.
:wink: :D
Lesson N°1 inherited from our friend Bill :
Near always, there is several ways to do something with PhotFiltre. :lol:
http://frontpagesolutions.com/photofiltre/index.htm
janBo
Système d'exploitation : Win XP Pro SP2
Processeur : 2.8ghz
Mémoire RAM : 1gb
Re: how to Move a selection?
Message par janBo »
Well I support move selection , why must I switch to Paint.Net or even far worse MS Paint just to move some pixels around
It should be an option in PhotoFiltre as copy+paste can is a lot of finger work.
It would be as simple as the way Paint.Net does it with the use of a hotkey to enable/disable move selection when a selection is made
http://img392.imageshack.us/img392/1529 ... 638mo4.png
Please please consider this simple feature
Why simply do when it could be complicated ? :)
Copy / Paste don't need to enable a subsidiary function to displace a selection.
When your selection is pasted, you can move it before validate, and more...
Did you try to do a right clic in the pasted selection ?
I think you should try PhotoFiltre a little more to realy appreciate it's simplicity. :wink:
