8bf filters
jimclatfelter
Système d'exploitation : Windows Vista
Processeur : AMD Athlon X2
8bf filters
Message par jimclatfelter »
I've written some 8bf filters that I'd like to share with PFS users. You can see what they are at http://www.clatfelter.net/8bf/plugin.html You can also download any you may want to try from this page. Some of them duplicate what PFS already does, but others add some editing capacity, especially for digital art. I hope you will find some of them useful.
Jim Clatfelter
Hi Jim,
Very great work ! The page is very impressive.
I will try these tools along this week.
Thanks for sharing them graciously.
:wink: 8) nice effects! thanks a lot! :wink:
:D : :D Excellent! Thanks a lot! :D :D
Very great work :)
Congratulaions :D
Jaume44
Système d'exploitation : w7
Thanks
Message par Jaume44 »
Thank you, Jim. :)
Jaume44
8bf Filters
I have been looking for 8bf filters to download in PFS with no success. I am certain there are more, but I cannot locate any.
:( Jack P.S. I am using PFS and loving it. Thank you Antonio da Cruz!
Hi Jack,
Look at this link :
http://www.fleursauvage.be/utilitaire/f ... iltres.htm
I recommend particularly Xero Filters and especialy Clarity, Porcelain ....
Erik Fou
Processeur : ?
Message par Erik Fou »
Thank you for every :D Jim C and bravos 8)
Erik
Jaume44
http://www.fleursauvage.be/utilitaire/filtres/filtres.htm
Tom,
Are all the filters in the two columns 8bf? What is the first for, top center dll?
Thanks, I am on it now.
Jack 8)
Jack,
Yes all the filters are 8BF, but I think all the filters are not there, many other sites could be found with "8BF filter" in a search on web. (with ")
Trying all the filters is very expensive in time and the forum is a good place to get knowledge.
The dll at top are needed by some 8BF filters to work correctly.
I tried more than fifty 8BF and i use less 8. :lol:
Jaume44
Thanks again
It took me a while, but I did go ahead and download most, if not all of the plugins. You are absolutely correct; it is going to be time-consuming to check out all of them, but I seem to have ample. It will be my hobby for a while.
Many will be discarded upon investigation.
Tom, I have to thank you for this link and all your constant support of me and all in the forum.
