using tools from photofiltre
Alain
Mémoire RAM : 1024
Message par Alain »
Hi
Is there a way to call "functions" from photofiltre that are available from the menu?
For example Image>rotate>free where the plugin gives the values??
It's easy to add the an easy way to select the horizon (just select two points), but it's a "lot" work to add a good roate function.
Alain
==> no :oops:
Alain
Mémoire RAM : 1024
Message par Alain »
Antonio a écrit :Is there a way to call "functions" from photofiltre that are available from the menu?
==> no :oops:
I thought so, but would have been nice.
Alain
Mémoire RAM : 1024
Message par Alain »
Just to make sure, I mean calling them from a plugin (not an external program).
Alain
