I installed the new version of PFS. The plugin.dll seems to be the same as the old one (3.0.64.101). Is this a new dll or the pld one. I tried Paint Engine and Impressionist plugins, but they still just turn the image black. I thought they might work with the new dll.
Is there a new dll?
Jim
8bf dll
Bill
- Version de PhotoFiltre : Free and Studio
- Système d'exploitation : Coffee
- Processeur : God Given Brain
- Mémoire RAM : Not as well as when I was younger
Jim:
You can dowload plugin.dll version 7.0.0.0 Here.
This won't help you with the Image Composer Plug-In (Bet you are surprised I knew where that one came from
) or Paint Engine Though.
I think both of those plug-ins predate PS 5. If you remember back when version 4 or 5 came out they changed quite a lot and a lot of the newer plug-ins for the 1st year or 2 did not work in Image Composer.
Jaume44
- Version de PhotoFiltre : Studio 10
- Système d'exploitation : w7
- Processeur : Pentium (R) Dual Core
- Mémoire RAM : 4 GB
PS Filters
I have installed a lot of PS filters in the plugins of Studio, thank you Jim for the information on Mehdi and Xero.
The problem: Many of my PS filters operate only on a partial area of my graphic in works, and usually the remainder is obliterated.
Do I need to place those filters in a special folder, or do I need a specific .dll?
I also get black images with some of the plugins.
The ones that do function are really great.
Thanks! Please, if this gets trashed for redundance, let me know.
Jack
Jack
jimclatfelter
- Habitué(e)|Habitué|Habituée
- Système d'exploitation : Windows Vista
- Processeur : AMD Athlon X2
Bill
