Is it possible to put a text on an other path... by example a line or a bend line...???
Greetings from Holland,
Marga
text 2 path
- Habitué(e)|Habitué|Habituée
- Version de PhotoFiltre : PF and PFS
- Système d'exploitation : W7
- Mémoire RAM : 3
- Version de PhotoFiltre : Free and Studio
- Système d'exploitation : Coffee
- Processeur : God Given Brain
- Mémoire RAM : Not as well as when I was younger
Marga:
There is a plugin available on the PhotoFiltre Site called Text to Path.
There is another plug-in called Contour to Selection.
The Text to Path Plug-in uses shapes from the selection folder. Basically you type in your text, select a shape and the text will follow the shape or path.
The Shapes or Selections are a pfi format file so if you want to create your own shapes like an arc to use for a path you need to have either PhotoFiltre Studio which will allow you to save shapes in the pfi format or download the Contour to Selection Plug-in for the free version of PhotoFIitre which will allow you to save your shapes or selections as a pfi.
I have a tutorial for using the COntour to Selections tutorial Here:
http://www.frontpagesolutions.com/photo ... /index.htm
- Mémoire RAM : 3
text 2 path
Hi Bill, thank you so much for the suggestion!!
I just made a new selection with the plugin Contour to selection, saved it and put a text on it with the plugin Text 2 path.
so far so good...
But: HOW can I influence the text.... by example if I want it red or thick or whatever....... is that possible in any way...???
Marga (from Holland)
so far so good...
- Mémoire RAM : 3
text 2 path
Hi Bill, thank you again..... fighting my way around I came to this: [/img]http://www.oudje.nl/bill.jpg
Cordialement,
Marga
Cordialement,
Marga
