Photofilter in the Context of the Explorer
sunnyid
Message par sunnyid »
AWESOME Programm :D
But i miss one feature...
I have Windows XP and want to use your program instead of paint, when i choose edit in the contaxt of the windows explorer..
But how???
Please explain.. i don't find it :?
Use the plugin "Association" to associate file format as PhotoFiltre
Stefan
Version de PhotoFiltre : 6.1.2
Système d'exploitation : W2k
Processeur : 300 Celery@450
Mémoire RAM : 768
Message par Stefan »
Association plugin
one could find here: http://plugins.photofiltre.free.fr/plugins.php?lang=en
Associate image formats with PhotoFiltre
sunnyid
No no no.. You missunderstand me.. :?
I mean, when you open the Explorer of Windows and choose a image format, and you klick with the right mouse button on the image format, their are some options in the contextmenu like: open, edit, print, copy etc.
I dont want to associate image formats with PhotoFiltre, i only want to edit them, by choosing "edit" in the contextmenu
It's because, when i choose edit, their allways open Mircosoft Paint Image
isn't it possible to edit the entry which open Microsoft Paint as the editing program?
Hi Sunnyid,
It's a Windows process :
Windows Explorer : Menu Tools/Folders options/ File types
Select the file extension you wish to edit
If avanced button is not available click on to "restore"
Click on advanced button.
Select "Edit" action, if exists, or New, create an Edit action and notify the path of PF
Cheers
sunnyid
Thank you for the tip :lol:
But i thought the standard edit-button entry could be edit, but it seems, that paint is too embeded in Windows
:cry: *whaaaaaa*
No matter, Sunnyid,
If you want not hack in the registry, you can create a new action like "Modify" or the name you wish.
Microbeurk make strides : compare XP to 3.1 ! Yes it was easy to improve :lol:
