newbie questions
kalmatt
newbie questions
Message par kalmatt »
How do I add text with a filled in background to a photograph?
Where do I find explanations for the tools that are in the toolbar on the right side of the window. For instance what is the "magic wand". what does it do, What is the "eye dropper", etc.
I need basic info and can't find it in the manual or "information" Thanks, Kalmatt :roll:
No documentation for the moment :cry:
"magic wand" is used to select part of image, click on the image to select pixels with the same color...
Stefan
Version de PhotoFiltre : 6.1.2
Système d'exploitation : W2k
Processeur : 300 Celery@450
Mémoire RAM : 768
Re: newbie questions
Message par Stefan »
kalmatt a écrit :How do I add text with a filled in background to a photograph?
Photofiltre free ?
- add an text, formated the way you want
- RMB on the selection rectangle around the text
- use "fill and stroke" to fill this rectangle
- add you text again
To simplify this i had an suggestion here on the forum
see viewtopic.php?t=2979
With the eye dropper you can select an color from an picture
- open an picture
- choose eye dropper
- move the eye dropper over the picture
   and LMBclick on the picture on an color you want
- see how the color on the right side on the top change ?
- now you could use this color to paint
