Doc PF Studio translated??
Marga
Version de PhotoFiltre : PF and PFS
Système d'exploitation : W7
Mémoire RAM : 3
Message par Marga »
Good morning all,
I just found the more than super document Antonio made:
viewtopic.php?p=22341#22341
I am Dutch and my French is not the best (better said bad...) so I would like to know if somebody has translated it into English or maybe even into Dutch. :?: I could translate it into Dutch from the English.... but from the French it is will be a problem.
Hope to hear from you :wink:
for the moment the french doc is not terminated. First we need ton terminate this...
