Antonio:
When uou are holding the Shift Key and working with the Line Tool you can draw straight lines 3 ways. This is good but the PaintBrush feature is better.
When you hold the Shift Key while using the PaintBrush you can draw a straight line between 2 points at any angle you want. This is a much better feature. What is even better with the PaintBrush feature is that it remembers the last point so you can keep going and draw a star or rectangle for instance.
Just Curious
Bill
- Version de PhotoFiltre : Free and Studio
- Système d'exploitation : Coffee
- Processeur : God Given Brain
- Mémoire RAM : Not as well as when I was younger
