Opening in thumbnail view
perfumer
Système d'exploitation : xp home
Processeur : 3200 amd athlon
Message par perfumer »
I am having problems getting PF to open in thumbnail view. Every time it's in details view, and I have to switch manually. Any way to set it for thumbnail all the time? I have my windows default to thumbnail, and that works for other programs, but no PF.
:?: I don't understand your question... Are you talking about Tool/Image Explorer ?
I use the standard windows open dialog box, and i can not set thumbnail view as default.
perfumer
Antonio a écrit :I use the standard windows open dialog box, and i can not set thumbnail view as default.
Yes, this is the problem I have. It is a problem to have to switch from details or list view to thumbnails each time. So everyone has this problem?
Hi, Perfumer
That means it's a Windows window !
and Antonio can't rewrite Windows, or use a special entry in the code to set thumbnail view as default. :wink:
OK now I understand your problem :wink:
...and I confirm Antonio can't do anything... Maybe in the Windows registery you could find a tip but you won't find this on PhotoFiltre forum :wink:
