Hi,
I'm using PhotoFiltre for a long time and now I got a strange error (both in PF10 & 11):
If I select an image and paste it to word or writer, the image is wrong by 3 pixels at the left... like if it was rotated or shifted to the right 3 pixels.
Here it is an example:
original image: https://drive.google.com/file/d/1Sm-EHw ... 7VTksnzNR4
shifted image: https://drive.google.com/file/d/11VexE4 ... IkquZGmikG
(also, notice the three dots at the bottom left of the image in color red, green and blue ???)
Strangest:
If I paste the image in excel there is no shifting.
Error when pasting images to LibreOffice writer & Word 2010
- Version de PhotoFiltre : 11.6.1
- Système d'exploitation : Win10/11
- Processeur : Intel i3-6100 @3.70 GHz
- Mémoire RAM : 16Gb
Re: If you don't speak french...
PhotoFiltre use only Windows Clipboard to copy/paste. I Think word use first pixels for other information.
Perhaps it's an option on LibreOffice or Word, check the paste options...
Re: Error when pasting images to LibreOffice writer & Word 2010
Strange... but you're right.
I can confirm that pasting the image with Ctrl+V results in a shifted image in Word, while using "Paste Special" as bitmap doesn't.
It seems Excel uses a different default paste behavior.
Thanks for your support!
I thinks the first pixels are used as native to formating (size, alignement, anchors, ...). If it's an another application exchange, it's better to paste as raw bitmap
