Hi,
I have a jpg of a dragonfly which is solid black, and would like to create an ouline of it,
using Photofiltre 7. Can this be done? If so, how?
Thanks,
.... john
creating an outline
Shinnen
- Mémoire RAM : 1.5 gig
Re: creating an outline
utilisez la baguette magique pour sélectionner la forme puis menu Edition > Contour et remplissage
Shinnen
OK. I'll try that.
Merci,
... john
Merci,
... john
