Some images cannot be opened
tit700
- Version de PhotoFiltre : 7.2.1
- Système d'exploitation : Win 10
I cannot open some images. Windows error message: "Image cannot be loaded". They are always images in jpg format. Most can be opened, some cannot. Why not? However, these images can be opened with other image programs.
Re: Some images cannot be opened
perhaps it's not a jpeg but other format like png ? what version did you use ?
tit700
Antonio, please search for any image you want to retouch here https://cleanup.pictures/ and download it. It is displayed as a jpg and then cannot be opened. I use the freeware version 7.2.1.
when i open it with PF11 it tell me that is a png image not a jpg. Just rename to png and open it...
tit700
It works
. For whatever reason
. Thank you very much! I'll write to the site operator.
the web site (or navigator) don't change the extension when saving, don't know why...
