Copy image with transparency to buffer
motion_theory
Message par motion_theory »
Hello my friend. When i copy image with transparent layer (PNG) and paste it to another program (excel or word) transparency disappear. I need to save file to png and to load it in excel every time. Why can not just copy and paste?
Re: Copy image with transparency to buffer
PhotoFiltre use the Windows clipboard, not a custom clipboard and the Windows clipboard don't supports alpha channel for bitmap type
