How to use two operating systems in one laptop?
JiyaHana
Version de PhotoFiltre : 2022
Système d'exploitation : windos
Processeur : intel i7
Mémoire RAM : 16GB
Message par JiyaHana »
Hi, I'm using Window 11 operating system and there I want to use Linux operating system too in a single device is it possible and how?
Please help me for this.
Thak you.
Re: How to use two operating systems in one laptop?
not possible photofiltre run only under windows, try with a windows emulator
JiyaHana
Mémoire RAM : 16GB
Thank you @Antonio for your suggestion.
Actually, In window operating system, I want to run Linux operating system for that I'm using VirtualBox. When did I set up the https://debian.pkgs.org/12/debian-main- ... 4.deb.html file with virtualbox then it's working fine but interface is not coming and here I need help.
Please give me helpful suggestion.
Thank you.
