matching colours
JiyaHana
- Version de PhotoFiltre : 2022
- Système d'exploitation : windos
- Processeur : intel i7
- Mémoire RAM : 16GB
matching colours
You can adjust the RGB values directly through an image editing application that allows numeric input for color correction then use the fill tool to apply the desired color.
Re: matching colours
Sorry but i had to divide this post from a 2 years old subject.
Mostly, i think you don't know the basics function of Photofiltre, because it use the tools you suggest,
like you could see upper in the last subject.
https://www.photofiltre-studio.com/foru ... 46#p186046
Shinnen
- Mémoire RAM : 1.5 gig
Ah yes, OK.
Thanks Tom.
..... john
Thanks Tom.
..... john
