Hi I was thinking but is it possible to create new filters or update the old ones?
New filters styles for writing and also save so that it is used by other subjects or new adjustments and other things like that?
New filtres
alicecullenefp
Re: New filtres
Plugin authors are either no longer reachable or have stopped development. I only work on the PhotoFiltre part and I no longer have time to do anything else
Which filters for example?
alicecullenefp
Re: New filtres
I would like if it was possible a filter to add effects for the writings and be able to save these effects so that other users can also use them.
New adjustments for photos and also these that can be saved in PFI format
And then maybe capture the colors of an image by creating color palette or palette.
minniechihiro20
Re: New filtres
En y réfléchissant une mise à jour des anciens filtres ou de nouveaux filtres ne serait pas mauvais, si vous regardez photofiltre cela peut donner tellement de
