Hello,
I have a problem to write č and Č after I reinstalled my computer. I have backup files on external hdd and after I opened it all č and Č were changed to é and É also I am not able to write č or Č in PF studio now. It was working well before reinstall. Where is the problem? I need to change something? I tried set win 7 in compatibility mode but it didn't helm me.
PhotoFiltre7
SK language
Win10pro
SK keyboard
I7 8th gen
GTX1050
32GB ram
2TB SSD
Interpinction problems
Re: Interpinction problems
perhaps you need to change non unicode char set in windows config (keyboard setting) ?
try the windows tool character table to test extended chars
don't know exatelly where is this option in windows 10 but try to find on the net "How to change non unicode language in Windows 10" and select slovak (because PF7 is non unicode and use this setting)
