Zoom
Lieselotte Gasper
- Version de PhotoFiltre : 11
Zoom
Zoom.
Hello.
I use PhotoFiltre 11 on Windows 10
Is there a way to adjust the zoom level freely or in smaller steps? The step from 100% to 200% is too big for me. For example, 150% would be nice.
Thank you for your answer.
Sincerely, Lieselotte
Hello.
Epsilon85
- Version de PhotoFiltre : PF 11
- Système d'exploitation : W11 64bits
- Processeur : AMD Ryzen 5900 HX 3.30 ghz
- Mémoire RAM : 32
Re: Zoom
Oui ce serait bien de pouvoir le faire, merci de cette suggestion.
Cordialement
Cordialement
Re: Zoom
sorry but zoom in PhotoFiltre use only integer multiples for zoom > 100%, it's for that 150% is not possible because it will create half a pixel (i know it's not easy to understand for non developper
Lieselotte Gasper
Re: Zoom
That's too bad.
In the range below 100% there are smaller steps. Maybe it's possible to make this possible in a new version?
Re: Zoom
when image is reduced, image pixels is rounded but when image i zoomed image pixel must be a square of screen pixel (for example 2x2, 3x3..16x16). The kernel of PhotoFiltre use this method, lot of work to change it because need to synchronize selection tools and paint tools, which is practically equivalent to rewriting the program...
Epsilon85
- Mémoire RAM : 32
Re: Zoom
Merci de cette explication effectivement abscons pour l'utilisateur lambda que je suis.
Cordialement.
Cordialement.
Lieselotte Gasper
Re: Zoom
Thank you for the answer.
Then I have to see how I get the problem solved. Unfortunately, it makes image editing a bit difficult.
Sincerely,
Sincerely,
JiyaHana
- Version de PhotoFiltre : 2022
- Système d'exploitation : windos
- Processeur : intel i7
- Mémoire RAM : 16GB
Re: Zoom
In PhotoFiltre 11 there isn't an option for incremental zoom adjustments like 150%. However, you can use the view menu and select Zoom custom to manually enter the desired percentage for a closer view.
kiwichick
- Version de PhotoFiltre : PhotoFiltre 6.4.0
- Système d'exploitation : Windows 7 Home Premium 64-bit
kiwichick
