Increase Font Sizes In PF
DougGuy
- Version de PhotoFiltre : 6.5.3
- Système d'exploitation : Wine in Linux Mint
- Processeur : I7 7700
- Mémoire RAM : 24GB DDR4
I use PF 6.5.3 and LOVE IT! It is simple, and does everything I need in a photo editor, been using it for years in Windows, and now 5 years in linux. It runs GREAT in Wine! I've gotten older now and my eyes are squinting at the text. How can I make the fonts in PF menus larger? Somewhere in this program data has to be able to change the fonts I hope, I looked in the .ini file and it's not in there, I don't mind editing the file but where to go with this? Thanks!
Re: Increase Font Sizes In PF
not possible by setting. In windows you can change dpi system value, perhaps it's possible to do it with wine ?
DougGuy
YES! There is a dpi setting in wine configuration that lets user change the dpi from 96 to whatever setting works, now it's very easy to read! Thank you VERY MUCH!! Mark this one [SOLVED].Antonio a écrit : 21 juil. 2023 9:33 not possible by setting. In windows you can change dpi system value, perhaps it's possible to do it with wine ?
JiyaHana
- Version de PhotoFiltre : 2022
- Système d'exploitation : windos
- Processeur : intel i7
- Mémoire RAM : 16GB
PhotoFiltre 6.5.3 doesn't offer direct font size adjustments but try adjusting system DPI settings or exploring Wine configurations in Linux for potential indirect changes.
