Images opening in small windows
kiwichick
Version de PhotoFiltre : PhotoFiltre 6.4.0
Système d'exploitation : Windows 7 Home Premium 64-bit
Message par kiwichick »
Is there any way change the default behaviour of opening successive images in one session in gradually smaller and smaller windows. Why can't they all just open at the same size?
Re: Images opening in small windows
to show the caption bar if you want to close or maximize...
use maximized mode, all image will be maxmimized
kiwichick
Antonio a écrit : 24 févr. 2023 9:05 to show the caption bar if you want to close or maximize...
Sorry Antonio, I don't know how I missed your reply. I don't want to open them maximised because I like being able to work on multiple images side-by-side. It's one of the things I love most about PhotoFiltre because very few image editors have that feature. I'd like them to open separately but at auto zoom size.
