Chinese/Japanese text issue
livio.franze
Version de PhotoFiltre : 11.4.1
Processeur : i7-10510U
Mémoire RAM : 16 GB
Message par livio.franze »
Hi, i have a problem with Chinese/Japanese text. When I enter text using Chinese or Japanese characters, everything looks normal, but if i save the project to a file (using the *.pfi extension), close and reopen it from the file, Chinese or Japanese characters are lost (they are replaced by question marks)
Is it a bug? Is there a workaround?
Using PhotoFiltre 11.4.1
Thank you
Re: Chinese/Japanese text issue
PF11 is unicode but for the moment pfi format is not unicode and text is converted to ansi to be compatible with the studio X version.
Before saving, convert the text layer to bitmap layer (menu layer). But the size is bigger and the text will be static (not a good solution but only this methode works)
livio.franze
Mémoire RAM : 16 GB
thanks, hope it will be fixed in the future
