Need help with plugins for Photofiltre Free
claudyarizhman
Version de PhotoFiltre : 10.14.1
Mémoire RAM : 4GB
Message par claudyarizhman »
Hello, I install Photofiltre Free software for my daughter, she uses a laptop with Windows 7 on it (64 bits). I use PF in recent past too. I am trying to install some PF plugins at plugin's folder, but nothing happens, don't shows at panel, even after restart PF. The plugins are Mirror, Aritimethic and Coller Dedans. Can you help me please? Merci :mrgreen:
Re: Need help with plugins for Photofiltre Free
what menu did you look in? some plugins are in the Image and Tools menus and not in Filter
claudyarizhman
Mémoire RAM : 4GB
Hi Antonio, the plugins are Mirror, Arithmetic and Color Dedans :mrgreen: :D :wink:
