It is possible to add the option in creating layers
jashleygraphics
Version de PhotoFiltre : 10.14.0
Processeur : acer
Mémoire RAM : 2 gb
Message par jashleygraphics »
It is possible to add the option in creating layers also create a group (a folder spece where the various layers are inserted?)
And is it possible to drag one-layer adjustments settings to a new photo without putting them manually?
Re: It is possible to add the option in creating layers
for the moment it's not possible, it's really complicated to develop because the program is not designed for that originally :cry:
jashleygraphics
Processeur : acer
Mémoire RAM : 2 gb
Understood, if you work on it with some new update? Let's face it, photofiltre lacks some functions but it is one of the lightweight and easiest to use programs ;) (also for Win 32)
