When I shrink an image by clicking the - (dash) button (orange arrow) the restore buttons are not visible on the bar at the bottom of the workspace (blue arrow) of the image that has been shrunk.
If I move the mouse pointer to the image all I can see is the Close X button and I have not been able to restore an image, just close it out (red arrow)
I have uninstalled PhotoFiltre Studio X, run CCleaner and deleted files/folders from C\Program Files (x86)\Photo Filtre Studio X (could not find anything in the AppData folder) and reinstalled the program -- without luck.
Any suggestions, please?
Shrink Image cannot restore with button
akbenjamin
- Version de PhotoFiltre : basic - pgotoshop
- Système d'exploitation : linux-mint
- Processeur : i7 nxt gen
- Mémoire RAM : 32 GB
Re: Shrink Image cannot restore with button
i think you resized the image windows, not the image. To resize the image use the menu Image > Image size only
akbenjamin
Okay, I will try, I was thinking about something different approach but I will try this one also, Thanks for the response.Antonio a écrit :i think you resized the image windows, not the image. To resize the image use the menu Image > Image size only
