Program window opening maximized
fadder_pf
Message par fadder_pf »
Hi!
A newbie question for PF11:
The program starts maximized always when opening. I prefer a display in the normal window. PF7 did that.
I see no option to define the starting behaviour.
Is there a solution?
Re: Program window opening maximized
don't understand, just reduce the windows, no ?
Where is pf11 installed ? on the "program files" folder or on "c:\photofiltre11" (or other custom folder)
If it is installed on "program files", some times you need to start photofiltre in admin mode to save préférences because windows 10/11 locks this folder
fadder_pf
That (opening in admin mode) helped!
In following usage PF opens in normal (not maximized) window mode, as intended.
Thanks!
:clap:
