I have moved from PF 7 to 11 and the zoom has been reversed
HeartPlusUp
Message par HeartPlusUp »
Simple question really, I have been using this program since I was a kid, and I wanted to know if I could reverse the Zoom functionality to how it was in PhotoFiltre 7 and lower. Sorry if this has been asked before I just couldn't find it. I looked though all the settings I could find.
Re: I have moved from PF 7 to 11 and the zoom has been rever
yes for a long time, even in the studio X version. It is to comply with the standard
ivana-jooloo
Message par ivana-jooloo »
is there any chance there will be an option to toggle it to reverse? I've used photofiltre 6 for years and have strong muscle memory developed for this being the opposite.
sorry no, it's now the standard for windows, android and mac, so it's better to get used to it :wink:
ivana-jooloo
Antonio a écrit :sorry no, it's now the standard for windows, android and mac, so it's better to get used to it :wink:
ok thanks.. . so then can I have a way of applying my license to photofiltre6? it meets all my needs (layers only serves to add complexity for what I'm looking to do to be honest).
Possibly why I've struggled to adopt other apps is this scroll, ha ha
the v6 don't need licence to free use, for commercial use contact me by mail
