How to Sort by Date in Image Explorer
TheOneGuy
Version de PhotoFiltre : 7
Système d'exploitation : Windows 10 21H1
Processeur : AMD Ryzen 5 3600+
Mémoire RAM : 16GB
Message par TheOneGuy »
Hi,
How do I sort images by date in Image Explorer?
There is a Sort with checkmark but it does not make any difference when enabled or disabled:
Re: How to Sort by Date in Image Explorer
no, only sort by name :cry:
kiwichick
Version de PhotoFiltre : PhotoFiltre 6.4.0
Système d'exploitation : Windows 7 Home Premium 64-bit
Message par kiwichick »
Antonio a écrit :no, only sort by name :cry:
It doesn't appear to sort by anything. As TheOneGuy said, checked or unchecked makes no difference to the order.
alphabetical, but after loaded it will not change, only for next load or refresh (F5)
