I try to propose it again
Re: I try to propose it again
what smallest program for example? because I don't know any smallest program that does that, only commercial programs that depend on "big" companies
Marisa
Message par Marisa »
Pollar - Picsart - Lightroom mobile - Artweaver - gimp
Marisa
Photopea ( online)
why don't you use one of those in this case? it seems obvious that photofiltre does not meet your needs so it's normal to look for another one, I'm for the competition, it's not a problem for me ;-)
Marisa
Because some of those programs you can not do what Photofiltre does and then I like to be able to give many graphic resources to those like me who use photofiltre, just see on facebook graphic pages for passions that give graphic material related to photoshop type PSD
jashleygraphics
Version de PhotoFiltre : 10.14.0
Processeur : acer
Mémoire RAM : 2 gb
Message par jashleygraphics »
It would also be fine photo black and white if only when I go to save it in "PFI" format kept the file in layer format so you can use those settings on other photos :D
minniechihiro20
Message par minniechihiro20 »
Actually this function on Photofiltre studio there is just go to "Adjustments" - Customize would be to fix because I noticed that it not only changes the chosen color but also the colors, I attach an example.
If you want from here you could then think about how to save it in PFI format.
:D
https://i.imgur.com/ve7Y0xr.jpg
saturation looks perfect. The shade must be fixed
https://i.imgur.com/Na13AJy.jpg
[Tom] Please respect the image size defined in the Announcements. I transform the display of the image into a link. [/Tom]
So I don't see why they have to request a feature that is already there and when could it just be updated? Use photofiltre studio 10.14.1
I completely agree with your various remarks but as I already said in a previous exchange, if I modify the PFI format for V11, it will no longer be compatible with the Studio X version and for the moment, the Studio X version is much more used than v11, so I can't make an evolution of the PFI format for the moment
minniechihiro20
Is it a suggestion if you try to make an external mini program just for this? Come photo Black and white?
Obviously I await news / updates in this regard. :D
