I try to propose it again
jashleygraphics
- Habitué(e)|Habitué|Habituée
- Version de PhotoFiltre : 10.14.0
- Processeur : acer
- Mémoire RAM : 2 gb
I know that it is not possible to have level - Adjustments - Partial Hue / Saturation, but a filter that is added in the layer menu that gives the functionality of partial hue / saturation through the channels and saves the file in PFI format?
All programs, even the smallest ones of Photofiltre have this function and I'm sorry not to have it also on Photofiltre and every time I have to change the program to be able to do something like that.
Re: I try to propose it again
why you don't use a layer with your correct adjust ? In this case you can hide/show the layer to compare with native image, don't need dynamic adjust and layer can be saved in pfi
jashleygraphics
- Processeur : acer
Where can I find the correct adjustment? Example? Sorry
You have all the filetrs in the menu Adjust and all the filters in the menu Filter > Color, what did you need more ?
jashleygraphics
- Processeur : acer
No in the levels I have no filter :O
So if I misunderstood there would be an "adjustmen" filter in the level menu that allows partial saturation?? :O
send me screenshot because i don't understand...
jashleygraphics
- Processeur : acer
Original
Exemple
I meant a menu so in the level that allows you to save the file in PFI format
Exemple
In PhotoFiltre 11 I started a function like this but it is not of very good quality because I have not yet integrated the radius option
(menu Filter> Color> Partial desaturate)
jashleygraphics
- Processeur : acer
What if you transfer it to the level menu like adjustments? In the world that the file can be saved in PFI format and use the settings on other photos? like the colors of photoshop to be clear.
Or as a filter always in the level menu that can also be used in previous versions?
no, for me it's a color filter and not a simple adjustment, so it is well placed in the menu Filter > Color
jashleygraphics
- Processeur : acer
It's a shame because if I want to make graphic resources (coloration in format PFI) to make those with shade and / or partial saturation I have to change the program
Marisa
I also believe that it is a pity not to have the function hue / saturation channels in the menu "levels" even programs with few functions compared to Photofiltre have the ability to change shades make a partial desaturation through the layers and save them in the format of the program itself.
Marisa
What's new about the partial saturation hue function? In my opinion it would be very useful if it is included in the "level" menu
i already answered, for me it's a color filter and not a simple adjustment, so it is well placed in the menu Filter > Color
Marisa
I'm sorry for this because even the smallest photofiltre programs have this setting in the level menu, and a pity that Photofiltre Studio does not allow you to do it and save them in PFI format.
