64-bit version has problems with lots of images at once
sypa2021
Version de PhotoFiltre : 11
Système d'exploitation : Windows 10 Home
Processeur : i7
Mémoire RAM : 16
Message par sypa2021 »
Let me first point out that I'm very happy with this 64 version. :clap:
No more memory issues as was the standard with version X. :D
However, I found a serious issue to be addressed. :(
As I collect many images for bulk processing, I encountered that after a while every image will be shrunk to a smaller size than the previous one.
In other words: after every "Paste a new image" or opening the images, they are rapidly getting smaller and smaller ... and eventually become invisible in the workspace.
They do exist after pasting or opening, but you have to go to the 'Tile vertical' or Tile horizontal' to make them at least visible again.
That's NOT what you want, as you want part of your workspace being clean (as in the standard 'Arrange all').
Weird enough, even after 'Tile vertical or horizontal' every next image also "magically disappears."
Advice for solution: leave each and every pasted or opened image visible. Big or small doesn't matter, but there should always be a kind of minimum visible size. Just stack them on the left as what 'Arrange all' apparently is supposed to do.
Thank you.
(I run a 4K monitor with an i7 processor)
Re: 64-bit version has problems with lots of images at once
I understand but why do you need to open lot of image ? In this case i use the image explorer to display all image at the bottom and i open only image needed to copy/past for example or to compare.
Do you think it's better to open all image at left and top of each other and hiding the title ?
sypa2021
Processeur : i7
Mémoire RAM : 16
Antonio a écrit :I understand but why do you need to open lot of image ? In this case i use the image explorer to display all image at the bottom and i open only image needed to copy/past for example or to compare.
The image explorer seems only for already saved images, otherwise that would have been a simple solution.
Lots of loading from memory is another story. The workspace kind of continues, and crosses the border.
I have checked it out, but version X had that same issue.
This problem came up as I have a lot of pictures that I run through Gigapixel i.o. to increase the quality. Many images with the same quality (usually from the same source and size) can be bulk processed by GP.
Are you sure there is no (simple) solution, like that the workspace cannot be overflown, and that all images "lowest" point is "standing or laying down" at the bottom of the screen?
==> no except display over every 5 or 10 images for example
if you have a solution, I would like a screenshot with 10 opened images for example
sypa2021
Processeur : i7
Mémoire RAM : 16
Antonio a écrit :Are you sure there is no (simple) solution
I have some screenshots, but how can I send them?...
use goopics.net or other image server...
sypa2021
Processeur : i7
Mémoire RAM : 16
Antonio a écrit :use goopics.net or other image server...
Honestly, I have even no idea what that is... :D
Can't I just send them to a simple email-address?
It's only to show my point.
On the other hand, you can test it yourself easily.
Just keep on pasting the same image and see what happens.
I'm pretty sure, it's a matter of some kind of a "maximum" setting.
Maybe it's a (simple) solution to just say: paste EVERY picture in the top left corner. Problem solved.
Or after (e.g.) 20, 40 , 60, 80, 100, etc. reset the position to the top left corner (so 21, 41, etc will be positioned there).
That they stack is not a problem. It's even inevitable. It's a problem that they disappear from the screen.
I use PF also to make movie stills using the same background. That's why the layer issue that you'd solved was such a "biggie."
I do love the program, especially for its intuitive dealing with it. That's why I bought it.
So IMHO for its usability it's close to being perfect and this looks to me that it really can't be a big (programming) deal.
==> yes it's my solution too (display over every 5 or 10 images for example)
I will see that in the next release (no date for moment)...
sypa2021
Processeur : i7
Mémoire RAM : 16
Antonio a écrit :reset the position to the top left corner (so 21, 41, etc will be positioned there)
Thank you, Antonio! very much appreciated.
Is there a way that it will be announced for English speaking people? (excusez-moi...)
sypa2021
Processeur : i7
Mémoire RAM : 16
And so you did!
I've just realized there was an update and tested it.
Awesome job, Antonio!!!
Thnx.
