I created a new nozzle transparent png file based on the attributes of an existing nozzle. I named it 'Leaves.png' and placed it in the Nozzles folder with the other files. Then I restarted Photofiltre and began a new project. When I went to the nozzles module, my Leaves.png file isn't there. So how do you add a new nozzle. I can't find any help or tutorial for this.
Thanks for any assistance,
Frizzell
Adding New Nozzles
Frizzell9
- Version de PhotoFiltre : 11.3.0 (64-bit)
- Processeur : AMD E1-1500 APU 1480Mhz, 2 Cores
- Mémoire RAM : 8GB
Re: Adding New Nozzles
Hi,
see this topic on the nozzles :
viewtopic.php?f=21&t=15573
and tell us if you can use a new nozzle with this method ?
