Opening images without consecutively reducing display size
Frizzell9
Version de PhotoFiltre : 11.3.0 (64-bit)
Processeur : AMD E1-1500 APU 1480Mhz, 2 Cores
Mémoire RAM : 8GB
Message par Frizzell9 »
Is there any way to open several images without PhotoFiltre progressively reducing the initial display sizes until they are as small as thumbnails? See screenshot (via URL): https://bit.ly/3Cxx6xB
Thanks, Frizzell9
Re: Opening images without consecutively reducing display si
use the full screen mode (menu display > Maximize when opening)
kiwichick
Version de PhotoFiltre : PhotoFiltre 6.4.0
Système d'exploitation : Windows 7 Home Premium 64-bit
Message par kiwichick »
Frizzell9 a écrit :Is there any way to open several images without PhotoFiltre progressively reducing the initial display sizes until they are as small as thumbnails? See screenshot (via URL): https://bit.ly/3Cxx6xB
Thanks, Frizzell9
I would like to know this too. So frustrating when opening lots of images. I would also like to know why the app is even designed to do this. Unfortunately I don't think Antonio's reply of opening in maximise is really a solution. The one thing I absolute love about PFS above nearly every other editor out there is the ability to have multiple images open side-by-side and view them at the same time. Opening in maximise doesn't allow that.
JiyaHana
Version de PhotoFiltre : 2022
Système d'exploitation : windos
Processeur : intel i7
Mémoire RAM : 16GB
Re: Opening images without consecutively reducing display size
Message par JiyaHana »
PhotoFiltre settings to disable automatic resizing or thumbnail display when opening images to maintain their original display sizes and manually you can reduce image size with Jpeg Compressor it will compress images without losing their original quality.
Thank you.
