Font error when save PFI
HNSon.art
Version de PhotoFiltre : 11.3
Système d'exploitation : Windows® 10 64Bit
Processeur : Intel® Xeon® E3-1505M v5
Mémoire RAM : 16GB DDR4
Message par HNSon.art »
I type Vietnamese and use a font that supports unicode before saving, everything is fine, but after saving as PFI format, all the text has font errors.
https://i.imgur.com/G9a6k2U.png
[Tom] I transform the image as a link.
The size of the images displaid in the posts are limited to 800 x 600 pixels :wink: [/Tom]
Re: Font error when save PFI
Yes the pfi format is non unicode for the moment :cry:
you can convert layer text to layer bitmap but you can not change the text after...
HNSon.art
Antonio a écrit :Yes the pfi format is non unicode for the moment :cry:
I hope in the future it will be unicode supported. It is a great format for creating template files like PSD format of Adobe PTS.
not sure because if I do that, the Stduido X version (older version) will not open it, don't know what is better...
HNSon.art
Antonio a écrit :not sure because if I do that, the Stduido X version (older version) will not open it, don't know what is better...
I think the PFI file format should support unicode and of course it's best to still be able to open files in older versions. This is the future of PFI file as well as Photofiltre Studio to replace other software in the work.
There was a time when I wanted to give up when the amount of text in the PFI file was too large, and the font was completely damaged. :cry:
big font needs lot of memory because PhotoFiltre convert it as bitmap for effects, perhaps the memory as been full...
