Change selection ratio
Onktebong
Version de PhotoFiltre : 7
Système d'exploitation : Windows 8.1, 10
Processeur : AMD E-450, AMD Ryzen
Mémoire RAM : 8 GB
Message par Onktebong »
Hi, I need to crop a few portraits to identical ratio to make a "trombinoscope".
I need to make a selection with a fit ratio of 3:4 (3 width to 4 height) in a picture with horizontal orientation.
Somehow Photofiltre seems to sense whether a picture is horizontal or vertical and adopts the orientation accordingly (4:3 for horizontal and 3:4 for vertical).
I this possible?
Merci!
Re: Change selection ratio
no, you must create 2 folders, on for vertical and another for horizontal and batch separatelly (by folder)
