Hi,
I have photographed a label, using two different settings on my camera. The label is supposed to be black and white, but one of the settings produced an image which has a somewhat yellowish-orangish tint.
The dropper tool tells me that the composition is:
Red ...... 164
Green ... 92
Blue ..... 42
I would like to change this colour (above) to the same as my white label, which reads:
Red ...... 157
Green ... 119
Blue ..... 98
Is there a way of doing this?
Thanks,
...... john
matching colours
Shinnen
- Mémoire RAM : 1.5 gig
Re: matching colours
you can use color balance to adjust...
Shinnen
Hi Antonio,
There's no way of plugging the RBG values I want into an app that will allow me to use the spray or fill tool to change the colour?
Thanks for replying.
..... john
..... john
don't know function like you want...
- Mémoire RAM : 12 Go
Shinnen
Hi,
Yes, that's it.
Thanks Patrick.
...... john
Yes, that's it.
Thanks Patrick.
...... john
in this case I did not understand the question
Shinnen
Hi Antonio,
I wasn't able to find a way of applying Patrick's suggestion.
I thought it would be simple thing to apply the RGB readings from one label to the RGB readings of the other label. It seems I was wrong.
Basically, what I want to do, is replace the tinted area (which should be white) in the photograph of a black and white label with the same shade of white from another photograph. The colour replacement feature works, but does make subtle intensity variations. The histogram seems to do it, but I haven't found a way of applying the colour from one label to the other label.
...... john
...... john
Hi Shinnen
you can find an issue around the way of this post :
https://translate.google.com/translate? ... 6t%3D23219
Shinnen
Hi Tom,
It's going to take some time for me to digest all of this.
Thanks for your help,
...... john
...... john
